It is currently Sun Jul 27, 2025 6:08 am
 Post subject: Martin 0 and OO
PostPosted: Mon Feb 28, 2022 7:21 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
Can anyone tell me the dimensions of Martin 0 and 00 sides - width and length?
Thank you.
Jim
 Post subject: Re: Martin 0 and OO
PostPosted: Mon Feb 28, 2022 8:43 pm
12 or 14 fret ?
PostPosted: Mon Feb 28, 2022 11:36 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
bluescreek wrote:
12 or 14 fret ?
Assuming they're close, either. Just an approximate measurement is fine.
PostPosted: Tue Mar 01, 2022 8:08 am
From the Longworth Martin book:
Martin O 12 fret - depth of body upper part 3 3/8 inches, depth of body lower part 4 3/16th inches
Martin OO 12 fret - depth of body upper part 3 1/4 inches, depth of body lower part 4 1/16th inches
Martin O 14 fret - depth of body upper part 3 13/32 inches, depth of body lower part 4 1/4th inches
Martin OO 14 fret - depth of body upper part 3 11/32 inches, depth of body lower part4 1/8th inches
The sides are tapered, but the waist area creates a "hump", so unless I have a side template I cut them to the largest width, bend them, mark and trim them using the radius dish. I build mostly 12 fret instruments and make the sides slightly over length at 32 inches. If I am laminating sides I will make them 36 inches. 30 inches is the finished length of the sides for the OO - 12 fret guitars I build. If you use a wide tail wedge and a Gibson style heel you might be able to "cheat" that a little, but I would in most cases just build a smaller instrument.
PostPosted: Tue Mar 01, 2022 8:25 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
These are from notes taken during measurement of vintage instruments, so measure your prototype if possible to confirm:
Bare minimum for side blanks:
14 fret/12 fret 00: 4-1/4 x 30-1/4 and 4-3/16 x 29-3/8
14 fret/12 fret 0: 4-1/4 x 27-1/2 and 4-5/16 x 28-3/8
This assumes no allowance for perfecting the neck and tail block area if bending on a pipe, and minimum depth is very close to the maximum side depth including binding. I've seen narrower classical sets used for these shapes, but some skill is needed with the linings as they need to follow the plate profile rather than the actual top or bottom edge.
- Beth Brower
These users thanked the author Woodie G for the post: runamuck (Tue Mar 01, 2022 8:52 am)
PostPosted: Tue Mar 01, 2022 9:03 am
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Thanks Woodie and everyone.
